my arlo camera works fine using the legacy app. also works fine using the computer. I am unable to set up the new app. app is unable to find the camera. I'm pretty sure my phone is on my wi-fi network but when it comes to the "searching for device" step in setup, it cannot find any camera. I tried "removing" the camera and "reinstalling" using the computer, still no luck with the app.
again:
works ok with legacy app
works ok with computer
cannot complete setup with new app
for some reason when I clicked on the "new app" I had to "sign out" and sign back in under my account, then everything went ok
There is no re-setup required when apps get updated or even deleted and reinstalled.
Your setup is stored on the cloud and the moment you re-enter your userid and password the app will repopulate with your devices.
