Is there a way to make a separate schedule for each camera? If not, is it in the works?
  • 1 Reply
  • 2117 Views
Roydel
Is there a way to make a separate schedule for each camera?  If not, is it in the works?  E.G., I want one camera to run all the time, but others on the same network to only run at night.
Probably not in the way you think but, yes, it can easily be done. What you do is to create as many custom modes with only the cameras needed at any point having rules (any camera without a rule is disarmed). Once you have all the modes for the various time periods configured, set them appropriately in the schedule. I recommend using a browser to do this since the app sometimes has issues.
