New App Update Issues
Have anyone noticed that with the new app uodate and firmware updates that the refresh is slower and that connecting manual is slow also? Besides this fact the new battery readback on the lower right doesnt match what is in the more info section? So when you runnout of battery it says so on the more info and on the live pic window it says you have a little left?
7 REPLIES 7
cyang64,
Have you tried to reboot your router & base station and test again?
Yes , rebooted everything and even removed all devices and readded back on and still the same problem.
cyang64,
What device are you using to view with the Arlo Mobile App & What OS is it running?
Running on iphone with ios 11.3 with the latest arlo app
cyang64,
Can you try and update to iOS 12.1 and test again?
Yes have tried this on my ipad with the new ios and still see similar problems. I have rebooted my ipad, uninstall the app and reinstalled it and still very similar issues.
cyang64,
Does this occur while using WIFI or cellular data on the devices?
