Netgear Base Station VB3000 and Optimum's Altice WiFi system
About two months ago I converted my cable subscription to the Altice system. I connected my Netgear base, via the ethernet plug and it imediately synced with my app and cameras. About two weeks ago, I suddenly lost the snyc connection and no matter what I tried, it won't sync. The base is good, tried it on a neighbors Modem. Optimum says it must be a problem on my end but it has to be something with them. Is anyone else having problems between Arlo and using Altice?
What LEDs are showing on the base?
Power and Internet are green.
Cool. So the Arlo base station is powering on and has an internet connection. But you can't seem to sync the cameras, is that right?
No, not cool, as it won’t sync with the base unit itself which, you need before you can sync with the cameras.
Given the LEDs, you should be able to see the base in the app. Is your device definitely on the same network as the base? There's no double NAT situation going on with the router?
