Loggged in yesterday to check live view 1/5 /2019
screen message said to update - pressed update
after the update , when I sign it - there is a message on the screen “ your device is not connected”
anyone else have this problem ?
Is it still not connected? You might need to remove the device from your app/web client and then re-sync it. Then re-add the rules for that camera to any custom modes you use
Thank you for your solution - it worked and I’m back on line
