My Netgear Base Station Keeps Going Offline
Frustratingly our base station keeps going offline! It goes from the sublime to the ridiculous, there are hundreds of alerts then the base station goes offline. Given that it is imperative that the cameras are active all the time this is becoming very annoying and stressful.
Is it actually offline as indicated by the base station LEDs or is the app showing it as offline but then there are still recordings?
Hi, it’s actually off line with no recordings?
CJN2018,
What are you seeing that is indicating it's offline? The LED on the front of the base station, an error message in the mobile app, both? What do you have to do to get it back online? Are you able to see an internet connection with other devices when this happens?
Has anything been released to fix this issue. It happened to me again yesterday. When I go in the app the battery operated cameras Arlo pro2 shows a message that says your base station is offline. I have one camera which is an indoor Arlo Q which stays online and still works. It is a WiFi issue. My base station has the power and cameras connected but the internet light is out.
If the Internet LED is out, you don't even have a connection to your router. That can be caused by a bad base, cable or router port. Use a different cable and router port to see if that helps. If not, open a case with support here.
WHat are the LEDs on the base showing when "offline?" It may be the display that's off, not the system. I occasionally get something like this so I'll force close the app and restart - everything is fine then. You can also try a web browser to verify that it's an app issue.
I assume it's the power LED that's amber. That implies either a bad power supply or base. Why not open a case with support for faulty hardware and get it replaced instead of beating your head against a brick wall?
