won't connect to the internet
Details. WHat have you tried? What do you see? What are the LEDs on the base showing?
Hi R1209,
The more information you can provide will help the community try to resolve the issue. Please be as detailed as possible. I see you have tried a different ethernet cable, but have you tried to reboot your modem, router? what other steps have you completed?
Try another device (laptop?) using the same Ethernet cable and router port(s). If that works but the Internet light remains out, swap at the store for a new system or open a case with support here.
Hi R1209,
As jguerdat mentioned, if you can try to test this on a Laptop OR PC, this will help narrow it down. I have provided the Arlo Technical Support link for you below to further escalate this issue.
