My Arlos are not giving me a SOUND NOTIFICATION
My Arlos are not giving me a SOUND NOTIFICATION when it detects motion, why?
At first when they were new it did give sound , now with updates, I can not see where to check or figure out how to push notification sounds..
gypsy1999,
Be sure push notifications are enabled within the rules for your cameras.
How do I enable or disable push notifications on my Android device?
How do I enable and disable Arlo push notifications on my iOS device?
What model device are you using?
If using Android, log in to the Arlo mobile app and navigate to Settings > Notifications. From here you can change the notification sound.
