This article is for the Arlo Secure App with Library. If you have the Arlo Secure App with Feed, visit: How do I enable or disable push notifications on my Android device? - Arlo Secure 4.0
You can enable and disable push notifications at three levels: the mode level, the Arlo Secure App level, and the Android system level.
- To receive some Arlo notifications, but only in certain modes, edit the notification settings for each Arlo mode that isn’t sending you the desired notifications.
- To start or stop receiving all Arlo notifications for a while, enable or disable Arlo notifications in the Arlo Secure App.
- If you always want to receive Arlo notifications or never want to receive Arlo notifications, enable or disable notifications at the Android system level.
To enable or disable push notifications for a mode:
- Launch the Arlo Secure App on your Android device.
- Tap Mode.
- Select the device for which you want to edit notification settings.
- Tap the pencil icon next to the mode that you want to edit.
- Tap the pencil icon next to the rule that you want to edit.
- Select or clear the check box next to Push Notifications.
You still receive email alerts if they are selected for that mode.
To enable or disable Arlo notifications at the Arlo Secure App level:
- Tap the menu icon (…).
- Tap Settings > Notifications.
- Tap GO TO SETTINGS.
- Tap Notifications.
- Tap Show notifications toggle button to on.
- Tap Allow sound and vibration radio button.
You do not receive Arlo push notifications until you log back in to the Arlo Secure App. You still receive email alerts if they are selected in your camera's active mode.
To enable or disable push notifications at the Android system level:
- On your Android device, tap Settings > Notifications.
- Tap All apps.
- Tap on the Arlo Secure App.
- Tap on toggle button to enable or disable push notifications.
For more information on Arlo push notifications, visit: Why am I not getting Arlo notifications on my Android or iOS device?
Last Updated:10/21/2024
Article ID: 000039087
