Motion zone settings have disappeared
  • 9 Replies
  • 4142 Views
brencloud
When i installed arlo i set the activity zone but now the setting screen is
disappeared
When i find this??????
9 REPLIES 9
ShayneS
Hi @brencloud
Are you trying to set activity zones with your camera? Can you provide a little more context regarding this issue?
brencloud
i have 3 cameras but there is not more e function for set zone both in app and in web app.
I navigate all in app and web app but the tab or other to set zone is disappeared.
I search in forum and instruction but the path is disappeared.
App version 2.7.12_25660
ShayneS
Do you have a screenshot of the missing activity zone tab? You should be able to set activity zones for AC powered cams excluding the Original wire free & Pro camera.
brencloud
Here there was a zone editor now is not present in all screen of app or web app
were i find? No settings is change is only disappeared!
ShayneS
If you go on the Arlo App & select the capable AC powered camera, for example > Arlo Baby > (Select the 3 dots  ... ) > Device Settings > Video (Activity Zones) > create them & Save.
brencloud
Ok there isn't video activity zone attach ths screenScreenshot_20190817-170819_Arlo.jpgScreenshot_20190817-170827_Arlo.jpg
ShayneS
Hi @brencloud
Did you have a smart subscription or a free trail previously? A smart subscription/Add-On is required to use activity zones with the Original Wire Free camera
brencloud
we have free now zone is only for not free?
ShayneS
With the cameras you have, you will need a smart subscription to have battery operated activity zones. The zones need AC power, which the original wire free does not support.
