Motion zone settings have disappeared
When i installed arlo i set the activity zone but now the setting screen is
disappeared
When i find this??????
Hi @brencloud
Are you trying to set activity zones with your camera? Can you provide a little more context regarding this issue?
i have 3 cameras but there is not more e function for set zone both in app and in web app.
I navigate all in app and web app but the tab or other to set zone is disappeared.
I search in forum and instruction but the path is disappeared.
App version 2.7.12_25660
Do you have a screenshot of the missing activity zone tab? You should be able to set activity zones for AC powered cams excluding the Original wire free & Pro camera.
Here there was a zone editor now is not present in all screen of app or web app
were i find? No settings is change is only disappeared!
If you go on the Arlo App & select the capable AC powered camera, for example > Arlo Baby > (Select the 3 dots ... ) > Device Settings > Video (Activity Zones) > create them & Save.
Ok there isn't video activity zone attach ths screen
Hi @brencloud
Did you have a smart subscription or a free trail previously? A smart subscription/Add-On is required to use activity zones with the Original Wire Free camera
we have free now zone is only for not free?
With the cameras you have, you will need a smart subscription to have battery operated activity zones. The zones need AC power, which the original wire free does not support.
