Motion detection picks up traffic 100 ft or farther
Hello Blackharley,
I am interested in learning more about how your camera(s) are detecting motion. It is not likely that the traffic 100 ft. away is causing the camera to trigger a motion event. I can confirm a motion event is triggered by the change in heat (decrease or increase). Can you provide a detailed description of how your camera is mounted along with the sensitivity setting?
If you haven't done so already, check out the following link to view a video that will provide recommended placement of the camera:
I look forward to your next update. If you'd prefer to troubleshoot this issue via the telephone please send me a private message with your phone number and the best time to reach you and I'll do my best to accommodate your schedule.
Best Regards,
Christine
Arlo Team
____
Please click
***phone number edit out ***
Your passive IR detector will pick up motion from very far away if the signal is large enough and moving fast enough since it keys off of angular changes in IR energy. Sunlight has a huge amount or IR, and avoiding it is likely one reason why you recommend pointing the cameras down. The cameras should never be pointed toward traffic, even 100 ft away, if sunlight can reflect off of the vehicles.
