- 2
I need help, i cant login to thr app, it says unknown error
i already deleted the app and installed it again, didnt work
i have the same problem on my ipad
Message 4 of 27
14,625
26 REPLIES 26
See my answer on 2025-06-03 04:03 AM
I already set the verification to email.
Message 26 of 27
1,431
Try turning off both mobile data and wifi on the phone, and then log in. It will fail with no internet connection. Then enable wifi/data and try again.
(there's a an old similar issue where this process worked - it might not now, but is easy to try).
Message 27 of 27
1,425
- 2
