Leaving it out in the yard
Can I leave the arlo camera out in the yard? It will just be sitting on the soil in the yard so it will be exposed to the weather (sun, rain etc).
They're sealed unit so, yes, that should be fine. I have a couple that are directly exposed to weather. Be aware that sitting on the ground invites dirt/debris to be splashed into the motion detector and lens, affecting performance and view. Maybe mount it on a short pole of some sort (there's lots of mounts out there with the standard camera mount screw of 1/4-20) or build a short platform to sit it on.
