How to connect base station in second home
  • 2 Replies
  • 2687 Views
JWoodham
I am looking for instructions on how to connect a separate system to my current one in a different home. Help would be appreciated. Thanks.
You would simply do exactly the same thing as for the first system. The only catch will be if there are more than 5 cameras on the basic plan in which case the second system can't be added to your original login but will have to be added to a new account with a different email address. You can purchase an upgraded subscription to get around that limitation.
JWoodham,
In addition to the points made by jguerdat. You would start by clicking on "Add Device" on the cameras screen and then select which device you'd like to add. From there follow the on screen instructions. Please let us know if you have any issues!
