What is the latest firmware for the cameras?
Last one I had noted as production release was;
Arlo = 1.2.4941 ( may now be 1.2.5699 which was beta release )
Q cam = 1.8.0.5551 as of june 10
The FW that I'm running on all my camera's is 1.2.4941. Is there a newer verson?
Yours is the latest release. Anything with a bigger number at this point in time is a beta release.
Just bought the sytem 2 days ago, 7 27-16. Here is a copy past of my FW, HW
You have the latest firmware.
The reset time after a recording is done is problematic. I have never measured it but don't forget that not only does the system need to reset but the motion also has to be detected. Thus, if the motion has moved to a location where it's difficult to detect (distance, moving towards the camera instead of the desired across the FOV, etc.), the next recording may be delayed due to lack of detection. The current method of getting past this is to lengthen the recording time so the whole event is captured.
Thanks for the reply ! Ya i am well aware of the " logic " behind the camera. I have a controls/programming engineering background. My issue is why the lag, why not just record all the motion. Only thing i can figure is that if a camera pics up say leaves moving it could record until the batteries expire each time so a time out set was installed at 10 sec - 2 minuets... I have my cams in the back and front. The front one, in order to pick up someone comming onto my property the sensitivity needs to be 100%. The cam now picks up any movement, sometimes there is nothing there so am assuming its a bug or something small and im getting 30 second clips every 1-5 minuets.... Batteries are 4 days old and are allready at 40%... The lag time on it is around 10 to 30 seconds between recording. This is a deal breaker ! at 350.00 I see this camera going back.. Just not sher what system will give me what I need.... Looking like a wired in camera with cloud and or direct to PC recording.
Again THANKS for the reply ! Much Appreciated !!!!!
