  • 5 Replies
  • 6180 Views
  • 5 In Conversation
JeffS12
Untitled.jpgMy camera has a red tint to it (as pictured) and has for some time.  It varies a little due to the lighting, but still red tinted.  Is there a fix for this?  Also, Lately I have noticed that my email notifications are coming in about 3 hours late.  Is there a fix for either of these problems?  Thanks.
5 REPLIES 5
manfredz
Hero
Hero
in some cases opening the battery door for a minute, then recloses resets things and fixes the tint
If a reset of the camera does not fix the issue, contact Netgear Support
Tomo69
It's true, I gave it a few slaps with camera upside down, and the colour returned...It works 😁
reed918
My camera also does the red tint at times. Although it is fixed w opening the battery compartment, does anyone know what the cause is?
manfredz
Hero
Hero
(someone correct me if I don't remember it quite right). I believe the cause is the IR filter not moving out from the lens during the day, opening battery door clears this.  But if it happens all the time technical support should be contacted since your cam needs fixing and more than just resetting.
