- 2
Anyone know what the LATEST r7000 Arlo-compatible firmware is? Best i can find is R7000-V1.0.6.54_1.2.3.chk
Thanks! I might end up getting a base station, but will see how I go. Not the first to complain about buying this router on the basis of it's Arlo capabilities and then getting burnt! Makes me not want to buy a base station and give them more money.
Hi there,
Same issue with the firmware update here, old links for the R7000-V1.0.6.54_1.2.3.chk version are expired, could you please share a new one?
I'm using the R7000 as an Arlo base station from the very beginning without any critical issue.
I just need to revert to the last Arlo working firmware because I made the great mistake to update the firmware, so please share it with me if you have it.
It doesn't metter for me cameras and router are working fine, now.. can you share the required firmware with me? 🙂
Sorry, I deleted it long ago.
- 2
