LATEST R7000 Arlo-compatible Firmware thread
Anyone know what the LATEST r7000 Arlo-compatible firmware is? Best i can find is R7000-V1.0.6.54_1.2.3.chk
I'm wondering if you ran into the same problem as I did - installed latest Netgear firmware (1.0.7.2_1.1.93) and it removed the Arlo settings. Now all cameras are offline...
1.0.6.54 is the latest beta with Arlo support. I monitor https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk?topic-zoom=... to see if new firmware has been released. I also ask the Arlo question before installing any new release since there's been discontinuity in releases.
Thanks for the info everyone! I've downgraded and got my cameras back online. They should really have a better way to manage these firmware pushes and/or either drop or fully support Arlo...
I had the exact same problem! Upgraded the firmware and all support for my Arlo cam dissapered. 😞
Did you read this thread? The link to the latest Arlo-capable beta firmware is above. Do not upgrade your firmware without verification that it support Arlo. I post every time there's a new compatible firmware or monitor it yourself here:
Has any one heard a date when they will get the support back for Arlo? Strange that they just removes functions like that. 😞
There IS Arlo support but only in beta firmware. Why this has been such a problem is unknown although it appears to be an issue with 2.4GHz connectivity when Arlo support is added. The updates have been painfully slow with no ultimate resolution in sight. There's been a lot of complaints on the R7k firmware threads about this, even without Arlo. AT least that side has been addressed.
Would you mind to send me this firmware file?
Without any idea until you go into R7000 to see it gone now I have no cameras is there a fix to this problem if I would have known this I would have Never updated it
dieter_itt wrote:Would you mind to send me this firmware file?
I somehow missed this message. There are a few things for me to mention here:
1) You can download the latest beta firmware from my Dropbox account (the thread on the Netgear NightHawk firmware forum has been removed):
https://dl.dropboxusercontent.com/u/4960473/R7000-V1.0.6.54_1.2.3.chk
Reset the router, flash this firmware and reset again. Set up the router as if new. Do not use backed up settings files - start fresh.
2) You can monitor the firmware forum for yourself to see if/when new firmware has shown up here:
3) Do NOT update your firmware if prompted until you know that it supports Arlo. I monitor and post in the forum just mentioned to make sure that a new release does or does not support Arlo and will make announcements here, too.
This sucks!! Hope they are workink hard on adding it back.....
I totally agree! I bought my camara and everyting worked fine for several montch. Suddenly ALL SUPPORT is removed. 😞 😞
Arlo and Netgear, PLEASE RESPOND, WHEN WILL YOU HAVE THE SUPPORT FOR ALRO BACK????
They have released a couple of betas that do support Arlo - see the link for download above. However, when a production release will be available, I have no idea.
Wonder if it has anything to do with the ARLO Factory Reset Vulnerability? Bummer, but I will run latest firware and find a different camera solution. It seems like a bogus, but Netgear obviously has concerns to remove the functionality.
It's my understanding that a production release will include Arlo eventually. Just can't say when.
Thank you for all your replies - I'll just say that for a big market leading company - Branding an expensive Router as ARLO compatible, and then allowing the sale of other expensive cameras as a good and normal security investment, and then pulling the plug on the two - is neither consumer friendly, nor security minded.
As such - I would suggest that Netgear provides a FREE ARLO base to all customers suffering from this issue. Yes it's costly, but it's like a recall for a car. Sometimes mistakes are made, and then - commercially - the best way to go forward is to make your clients happy.
I still believe that R7000 flagship + Arlo makes sense. But I also want to maintain the best drivers that I can for my machines. This said - if that's no longer in the business plans of Netgear - then the company should compensate, those like us - who trusted it.
No?
My suggestion - please send us an ARLO base system to customers with R7000 & ARLOs so that we can move forward on this.
This is it, eather free base station or full refund for cameras!
You could always try asking nicely through support instead of demanding. I doubt it will help, though.
Yeah only problem that there is no contact email available for UK custumers!!!
I've searched the link provided, but can't find a link to download FW 1.0.6.54. I'm running 1.0.6.40 and would like to keep Arlo capability. Is anybody able to provide a download link for 1.0.6.54? Much appreciated.
It's not available from Netgear because support has been dropped completely. I would strongly suggest using the base station since both the router and the Arlo firmware are VERY old and will never be updated. I switched back to the base when they announced the dropping of support.
If you really want to hurt yourself, here's a link:
