Issues with 2 different base stations and different firmware
Hi,
I've finally (though it works half the time) connected another base station to my network for coverage. One is running 1.7.1 and the other is running 1.4.2695. When I go to update the firmware on the 2nd on (the lower code number) it says it's up to date. Is there a way to upgrade that code manually? Are the USB ports able to be used for that?
Thanks!
L
There's no way for you to update manually. The base and cameras should update themselves overnight automatically. A power cycle can help but after that it's all automatic. Keep checking.
