Hi,
I've finally (though it works half the time) connected another base station to my network for coverage. One is running 1.7.1 and the other is running 1.4.2695. When I go to update the firmware on the 2nd on (the lower code number) it says it's up to date. Is there a way to upgrade that code manually? Are the USB ports able to be used for that?
Thanks!
L
There's no way for you to update manually. The base and cameras should update themselves overnight automatically. A power cycle can help but after that it's all automatic. Keep checking.
