New add on camera quits after one image.
I just tried to install an add-on camera. I get one image and then it dies. After resync it will work again, once, and then dies. I have removed the batteries and started it again. Same problem. I have reset the base station, resynced; same problem. I have tried to use the mini usb feature. No improvement. It is still a one-shot-wonder. Battery indicator reports all is well. Prior to the new camera the system worked fine. Now it is a bit flaky and the only change is the new camera (brand new sealed box). The add-on camera is the third one for this system.
I am out of ideas. What am I missing?
Assuming you mean it's only the camera that's the issue, you could either return the camera for a replacement at the store you purchased it from or submit a trouble ticket for a possible RMA.
