Issue completing New Order with 15% OFF discount code provided ARLO... At check out, the discount is not accepted? please advise
AZSec,
What issue are you experiencing? Are you seeing an error message?
JamesC-
The following message ...when I add the code and apply at check out:
"The code you have entered is invalid. Please check your code and try again"
AZSec,
When entering the code, be sure no additional characters or spaces are being added (especially if you are using copy/paste). The code must be entered exactly as presented.
correct... I've tried adding again no space, even the dash between each the numbers/letter code.
Same error message? Please advise
AZSec,
I've opened and escalated a ticket detailing the issue you've described here. An agent will reach out to you with a status update as soon as possible.
