  • 29 Replies
  • 8770 Views
  • 3 Likes
  • 5 In Conversation
dfresh
Bought the 4 camera system about two weeks ago..Has been working beautifully.Then recently we had a severe cold snap of around 0 degrees for 2 days.The 3 cameras i have outside the battery level has dropped significantly Versus the one i have inside(hasnt moved since day one).Brought the 3 inside and battery level recovered.But now i have a problem with the ir light not going off after a live stream.Its like the camera is still on and i cant shut it off thru the app or website.I get camera is in use or busy.Only way to stop it is pop the batteries out.Ive tried rebooting,re-syncing,and reinstalling app to no avail.I also just ordered batteries to see if that could be the problem but ive never recieved a low battery message.Any help would be much appreciated
29 REPLIES 29
AveBreuxhouse
Yea, Its the way all modern tech works. They monitor community for issues and fix on the fly. I think the design and simplicity of Arlo is the best out there and they just released Q so support is there and that makes me feel good. Arlo has the ability to be a long running security system line of consumer electronics. Just trying to stay positive!
MuddCrabb
I understand what you are are saying ....but when it comes to security it just needs to work relible-like-ish hehe. I still dig my system I just wish it worked all the time.
AveBreuxhouse
Haha yeah I'm with you on that. Security has to be reliable.
dfresh
Do i dare say Its working flawlessly now..What ever they did i hope they keep it.
AveBreuxhouse
Heck yeah!
