- 2
Bought the 4 camera system about two weeks ago..Has been working beautifully.Then recently we had a severe cold snap of around 0 degrees for 2 days.The 3 cameras i have outside the battery level has dropped significantly Versus the one i have inside(hasnt moved since day one).Brought the 3 inside and battery level recovered.But now i have a problem with the ir light not going off after a live stream.Its like the camera is still on and i cant shut it off thru the app or website.I get camera is in use or busy.Only way to stop it is pop the batteries out.Ive tried rebooting,re-syncing,and reinstalling app to no avail.I also just ordered batteries to see if that could be the problem but ive never recieved a low battery message.Any help would be much appreciated
I understand what you are are saying ....but when it comes to security it just needs to work relible-like-ish hehe. I still dig my system I just wish it worked all the time.
Do i dare say Its working flawlessly now..What ever they did i hope they keep it.
- 2
