- 2
My Iphone8 worked for over a year. I had a problem connecting so uninstalled app and reinstalled. Now with 2-step verification everything looks like it will work, but at the end it says "Problem Verifying this Device". Same phone that worked before, now it doesn't (brothers android is working). I Deleted/Reinstalled App, same problem. Went into settings on laptop, removed phone from list, still not verifying. All Notifications are turned on for the App. Please help, I use these cameras to keep an eye on elderly mother and now I can't from my phone.
Best answers
I've escalated this topic. The development team is currently reviewing these reports. I will provide an update as soon as I have more information.
I just fixed click don’t trust and then it’ll ask you if you did clicked don’t trust by accident and it will ask you login again click that then it will work
@Dclough wrote:
Every time I go to trust this new device Arlo gives an error message. I have deleted & reinstalled the app twice with no luck.
Arlo says they are investigating, and likely will reply on this thread when they have a fix. In the meantime, you'll need to use the "Don't Trust" option.
Hi I was hoping to innvest in Arlo pro 4 x 2 as a spotlight and camera for the side of my house and I downloaded the app to see how seamless the app is but I too have had the same trouble with the app trusting the only device I have tried to tie it to. Clearly a bug that needs fixing but I might wait to purchase the camera’s with solar panel until I know the app is operational. Any updates would be appreciated.
Lori
This issue has been resolved. Please authenticate and attempt to trust your new iOS devices again and let us know if you still experience any issues.
Thanks,
The solution has worked for me, the Trust Device option in the app now works.
Good stuff!
- 2
