  • 10 Replies
  • 6538 Views
  • 2 Likes
  • 5 In Conversation
svt4cobra6
Have had the arlo system with 4 cameras about a month.  Three of the 4 cameras worked so sent one back for exchange.  Just got the replacement, put in batteries, hit sync on base station then sync on camera but it does not seem to be syncing.  Could be a bad one that was sent back to me but maybe an issue with the sync procedure.
Streak2
Master Master
You can try and restart the base, If that does not work, the last resort is to remove all devices and do a factory reset using the reset button.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
10 REPLIES 10
Streak2
Master Master
Don't push the sync button on the base for too long.
What lights how on the camera when you press the sync button?
What does the app. report during this time when you select add device?
GuiP
Hi, I have the exact same problem. Had one camera sent for standard exchange, just received the new one, impossible to synchronize it with the base. I press the button on the base for 2 sec, the light blinks, then do the same on the camera and the blue light also blinks but never stops. Suggestions are welcome.
brh
Have you tried opening the battery door of the camera and closing it again then trying to resync it?
Secondly, if that doesn't work, delete the camera from your system and then add it back.
Brian
GuiP
Hi Brian,
thanks for your quick reply. I did try to open the battery compartment and try to synchronise it again be without success. I tried a few times actually.
I can delete the camera from the system because I can't add it at all.
Shall I try to unplug the box to restart it?
Regards,
Guillaume
brh
Press the Power button on your base station and hold it for 10 seconds.
Brian
Streak2
Master Master
steve_t
Master Master
Brian
The power button has an on/off position so holding it won't do anything. If you're referring to the reset button, then the instructions as above should be followed
svt4cobra6
Got it working, just had to reset the base, camera seems fine!
steve_t
Master Master
Excellent. Good stuff
GuiP
Hi guys,
thanks a lot for your help. I got it working as well by just restarting the base.
