I gave it one last, best shot. I'm out of ideas. The system is going back.
I took the advice, and I swapped cameras to different positions. I opened battery covers and closed them again. I re-booted the base station. I lowered motion sensitivity (Then it wouldn't detect the motion.) There are no clouds in the sky whatsoever causing shadows. No motion at all, anywhere. I moved the car that the camera watches over, in case it was some sort of reflections off the windshield. Nope. Same problem with the car not there.
As you can see, it's just a bright flash, then 9 seconds of absolutely nothing. Wierd thing is, it doesn't do it at night under the night vision. Both cameras have shown the problem now, so it's not a problem in just one camera. I'm thinking it's related somehow to the sunlight, but camera is positioned well under my eaves, totally out of any direct sun at all. I can't move the camera anywhere else to be able to watch the car. See it here: Example Video & With Car Parked
I'm out of ideas, except to return these and try a different system totally.
Yes, it has to do with the sunlight.... that is a highly reflective concrete surface.... I can see it giving many false triggers.
Since you can move the camera anywhere else, you may need to use either a pixel based detection like the Q camera( will work thru windows ) or another type of unit.
BTW, the flash is just the iris adjusting to the high light level
guess you did see i meant "can't"
