The mode section says "Getting Information" and never changes. I can't get on with my phone or the computer. How do I reset this?
I have the same problem since this morning.
I can't change the mode with my iphone but it's possible with my PC.
I use 1 station with 8 cameras.
We are aware of an issue that is causing a problem when using schedules and changing modes. We are working to quickly resolve the issue and apologize for any inconvenience this has caused. Thank you for your feedback and we hope to bring a resolution as fast as possible.
I bought this system because I'm going to holydays.... but I cant go in the rules to set sensitivity or change the mode....
Message saying "please wait" or "obtaining infos"....
Ill go on holyday without been able to configurate my system.... I hope a commercial gesture from Netgear, I bought this system but I cant use it.... Ill be worried about my house during my hollydays...
Workaround : login on my old windows PC / Firefox
but it is still a major inconvenient
1 station 5 cam
If you use iOS, try Puffin App in the AppStore
Worked for my with the iPad and Iphone
Same probleme here! I can connect to my account and see my modes on my computer, but when I tap on the "modes" icon in both the Ipad and Iphone apps, all I see is the message "Obtention des informati..." (in french version of the app)... Even when I try to go on the web portal on these devices, all I see is a "Loading" message under the Arlo Logo...
It worked two days ago when I set it all up, but not today...
Same problem here,
Only reply two days ago: "can you perform a speedtest of your internet connection". What I did.
I answered : 189 mbit/s in download and 19mbit/s in upload....
From that answer total silence from support...
I would like that a engineer tell me what is happening. I have to go in holyday tomorrow, I bought this system to secure my house but I still can configurate properly in going in the modes and rules.
I feel my money has been stolen.
All my hardware at home is performant, my connection is fast but........ Arlo's system doesnt respond.....
I wait for a commercial gesture from Netgear: Ill go on holyday with my house unsafe. Could someone from the support call me or send me a real email? Not a pseudo answer on a support.
Best regard,
Thank you for your message...
No It doesnt work. Still stucked.... cant change any rule or modes....
No, it doesn't work. Cannot see & modify rules in the parameters section.
With the IOS app :
- we cannot access & change selected mode (ON/OFF) in the "Mode section"
- we cannot access & change rules in the "Parameters section"
With the web interface (arlo.netgear.com) :
- we can access & change selected mode (ON/OFF) in the "Mode section"
Exact same problem for me....
Can change modes using my Mac, but when using my IOS devices it just halts on "getting information"..
Same problem here. Cannot change modes on PC and Android too. And one of my camera is not recording on motion. When can we except the solution?
I can't access the mode menu and so I can not control the mode on/off functions, When will this problem be fixed?
i have the same Problem. I can change the mode on firefox,safari, but it doesn't work on any mobile device. Not on Ipad, not on Iphone. I need help. When will the problem be solved?
When will it be fixed ?
While there are Arlo/Netgear employees here, I don't count on forums to be the real problem solver. That's what contact with support through the established channel is for. I'd recommend a dual path - post here but also open a trouble ticket.
