Dead base station (VMB3000)?
The base station for our Arlo camera's seems to be dead - the only LED that comes on is the power LED which is just solid orange.
All the LEDs flash green briefly when first powered on but then the power LED goes solid orange and nothing else happens.
I've tried leaving it unplugged from power for days and have also tried resetting it with no change.
I think it needs to be replaced but wondered if there is anything else I can try?
thanks
Barry
You could possibly try a full reset of the base ...hold in reset for ten secs till the front LEDs flash.
If still Amber after, then Netgear Support is prob the answer.
Thanks, I'll give that a go - I've sent an email to start the process with them in the meantime.
Barry
