Why are there no alerts sent anymore for low battery? I don't expect daily updates, but a 25% left alert (or something) like we used to get. I see so many feeds on this site that say it used to exist but doesn't now, or has been turned off or something - that's ridiculous. I only found today that my front door camera batteries were completely flat, when I got an alert on the app that they required replacement - at 0%. That's mighty helpful - WHY IS THERE NO PRIOR WARNING!? I bought this system to protect my home - not to have it unprotected ALL DAY while I'm at work until I can get home. Also, having cameras go randomly offline because of being overseas and no prior warning of low battery (70% when i left) so for two weeks I had no coverage. I am considering returning this entire system and demanding a full refund - this is just simply not good enough. YOU SHOULDN'T BE TAKING FEATURES AWAY! And no, my email system is not blocking your emails either before you say it. I would like a non-scripted genuine response from someone at Arlo.
CAMERA FIRMWARE: 1.2.16720
BASE STATION F/WARE: 1.9.8.0_16666
Hello Community,
The issue with low battery E-Mail alerts not being received should now be resolved for the following Base Stations (VMB3010,VMB3500).
Please find the Release notes.
Arlo Base Station VMB3500 - 1.12.2.7_7_dd3c705 - 19th March 2020
Arlo Base Station VMB3010 - 1.12.2.8_556_dd3c705 - 19th March 2020
There will be a future update for the following Base Stations (VMB4000/4500/4540/5000).
MichaelJ81,
Low battery alert emails are still sent. This feature hasn't been removed.
Are you receiving other emails from Arlo?
They're also sent at 15%.
MichaelJ81,
There may be an issue with the cameras connection to the base station. Does the camera drop offline frequently or is the signal strength poor?
We are experiencing exactly the same problem. No low battery warnings (and we have never received these) and only a warning at 0%:
"Your Arlo Battery IS Tired - Your Arlo Garage Cam is running low on battery. You’ve still got about 0% of juice left, but in order to maintain uninterrupted peace of mind, we recommend charging up the device as soon as you can".
VERY FRUSTRATING.
Ottiehund,
Have you tried to reboot your base station? or remove and re-insert you camera batteries?
I don't get the battery alert emails any longer, and have experienced the same frustrations with discovering a dead camera only after having a package stolen (when the system was supposed to earn it's keep....).
Thinking maybe I needed to re-institute the email notifications, I can't stand the barrage of emails along the lines of "cat-spotted", etc. So have turned off email notifications under the mode setting (which by the way, is still totally buggy on the app, and the screens needed to access these settings are only accessible from my desktop).
So how does one resume email notifications on the battery alert? Thx
Have you checked to see if these emails are in your spam folder? Did you receive these low battery warnings in the past?
@ShayneS wrote:
Ottiehund,
With all due respect, that is all I ever seem to find suggested from 'Arlo' on here ---- neither of those suggestions work reliably (occasionally they will). Clearly there seems to be a larger issue with reliable connectivity. Last week we were away on vacation and a day in the camera dropped connection again, leaving us without coverage for thr remainder of our vacation, kinda defeats the puropse of having the thing doesn't it??
Simply unreliable, with improvements required to either hardware or software or both.
Are Arlo actually understanding this and working on a fix?.
I have had myArlo Pro camera for a couple of years and regularly got email warnings when the battery got down to 20%, then a grew additional warnings as it got lower. This tome I got a 20% warning, but no more. I realized I'd forgotten to check and the battery was completely dead with no additional warnings. Did something change? Is there a setting to set the warning levels?
Nothing has changed that I know of - I still get emails. There's no setting you can make to change behavior. Do you get other emails from Arlo? Maybe the emails are being blocked or put into spam?
I agree 100%. I used to get low battery warning emails and they just stopped. *?
Now when I travel and try to access one of my cameras it might be offline due to dead batteries. Batteries I could have replaced before leaving town. What good reason do you have for stooping this most useful feature? The arlo system and cameras are ot cheap. If this feature is not re-implemented I will bring all of my equipment back for a refund and find some other camera system that does the little things that make a difference and I hope everyone else reading this follows my lead.
peace
Same here - I used to get low battery alerts perfectly fine, however they have stopped since the past month or so - presumably since a recent app or firmware update. Lots of people seem to be complaining about low batter alerts no longer working (when they used to work fine previously), so please Arlo Suppport don't just suggest removing and re-inserting batteries - you have clearly broken something in a recent update so please investigate the issue properly and fix the issue that you have introduced.
Thanks.
I am no longer getting the low battery notifications either. Would like to know why and how to get them back so I can charge the batteries and not have cameras not working.
Same here - I am no longer receiving the low battery emails that I used to receive and batteries are going dead - thus the cameras are not working until the battery is recharged. It seems like useful features that once worked are either being purposely removed or broken. Are the low battery emails now only includes in the pay plans?
Hi @Rueg
Thanks. I will contact them.
I spent over an hour with support through a chat session. They said they would escalate the issue because it was a known issue. They asked a lot of question that don't really make sense to me - who is your internet provider - what is the make and model of your modem and router.
I contacted chat support today on the same issue and they said you would only receive low battery alerts if the camera was set to send email alerts - unfortunately, that also sends emails for every motion detected, which is nonsense. Mine also disappeared on or about June 12th.
My camera is set to send email alerts and I still no longer receive battery warnings, so I think Arlo support need to go back to the drawing board. I wonder if they actually use the product themselves (there's an idea, then they might well experience the issues themselves).
In my case, the batteries are actually dying and going offline. No alerts since the last firmware upgrade. Correlation does not equal causation but given the quality of firmware releases I am highly suspicious.
Which camera(s) are you experiencing the missing battery low emails with?
Did you update your case with your findings after troubleshooting with your case manager? (Case - 40995576)
