1 of my cameras has a colored image. Anyone know if it can be restored or is it broken?
Hi. 1 of my cameras has a colored image. Anyone know if it can be restored or is it broken?
See attached picture.
No pic yet...
Is it RED ? If so a common fault when the IR filter sticks. If under warranty, contact Arlo
If not;
Pull battery and reset cam ( sometimes helps )
Gently tap the camera on side to release same
Some say moving a strong magnet on side loosens it
Hello.
Yes it`s red.
Before I changed batteries last time it was red. It disappeared after battery change but has come back now. Have changed batteries to rechargeable but that did not solve the problem. Will try with the magnet.
Thanks for the suggestions and tips.
Anders /
