- 2
I turned off 2 of our cameras so it won't constantly record while we were out working in the yard but now I can't seem to find out how to turn them back on. Arlo says they are offline and they have new batteries.
I'm having the exact same problem.
The camera battery died while I was out of town on a business trip. I get back and plug it in, I turn the camera off while it is charging so it won't constantly record when sensing motion. went to check on it, after charging two to three hours to see how far along the charing has progressed, but it says it is offline.
so, I followed all of the suggestions I've read here, as well as removing the device and attempting to resync it with the base, but it doesn't sync. It started flashing blue, and then the red LEDs around the lens came on for a bit, then turned off, then turned on again (see attached photo).
What's next?
That doesn't seem normal. Did you try removing and reinserting the battery to reset the camera? When charging, did the blue LED show, indicating that the battery was charged? You may need to open a case with support here if it turns out to be a hardware problem.
I've tried everything, including removing the battery to reset the camera. The blue LED was flashing the entire time the battery was charging.
The blue fully charged LED only illuminates when fully charged and is solid, not flashing. If removing and replacing the battery and/or removing the camera from Settings, My Devices and resyncing it doesn't help, open a case with support here.
Talking to support now. for the second time today. 😞
WTF NetGear? Can't turn off and on the camera remotley? Spend some money on support team
and stop nickel and diming to get users to do your work for free. Shameful.
Ditto! Same trouble. Turned it off yesterday to fly the flag. Took the flag down, came back to turn the camera on and no toggle. Have tried Safari & Firefox and they are the same as Chrome. No way to turn it back on. We were about to buy more cameras but this thing has been nothing but trouble. Too expensive to constantly have trouble with it. Looking elsewhere for something that is dependable.
Corkys-Wife,
If you toggled the camera off, you should be able to toggle back on from the same location. Did you switch devices or are you logged into a different account (without access rights)? This could be why the toggle is not present.
Did you miss reading this entire thread? My reply says "ditto".....everyone on this thread is having the exact same issue. Turn it off, attept to turn it back on and the toggle is GONE! You're right about one thing only and that is if you toggle the camera off you SHOULD be able to turn it back on! Have not switched devices, not logged into a different account...which makes zero sense because if you were logged into a different account who's camera you had turned off you SHOULD be able to turn it back on! LOL! The thing is a piece of junk. It works great, when it works. We spend more wasited time than should be necessary having to get on a ladder, take it down, take out the batteries, put them back in, come into the house and re-sync the thing. Not optimal! Basically sucks.
Browser or app (which one)? I just tried both (Android app) and the On/Off switch is there. Try both methods (use a mobile browser if needed - use the browser menu to set it to use the desktop version of the site).
Did you try restarting the base from Settings, My Devices, your base, Restart?
- 2
