  • 4294 Views
DavidWhelan
I know I can set it to record 120 seconds per clip, which it will do even when there is NO subsequent movemement, but Is it possible to set the length of recording at 30 seconds and then have the motion detection re-trigger when movement is still occurring to record additional video clips?
Thanks,
David
Yes it will..... If there's more or continue motion, it will start a new 30 sec clip
Showguy
Virtuoso
Virtuoso
To be fair, Yes it will..... If there's more or continue motion, it will start a new 30 sec clip AFTER IT RESETS, RESTS AND YOU EXPERIENCE THE USUAL 4-10 second camera lag. So expect at least a 10-20 second blank spot between recordings.
DavidWhelan
Thanks for the replies - yes, I'm finding there's an initial 10 second delay before the recording starts, then a 10-12 second gap until it starts up again, so yes, I miss the first 10 seconds, and about 10-12 seconds in the middle...
I live in Phoenix Arizona and our outside temps are 100+ degrees, so maybe the motion lag time is worse than in most environments.
At this point I'm thinking Arlo is a great first effort, but still very much a 1.0 product.  Thinking of returning this expensive kit and waiting until Version 2.0
David
