  • 1 Reply
  • 14953 Views
BC1956
I deactivated my ayatem thinking it would turn the cameras off whilre I worked outside but now I can access the account but can't find how to re-activate my system?
Showguy
Virtuoso
Virtuoso
If you go into " SETTINGS" / BASE STATION SETTINGS, you will see options to activate or deactivate.
I guess you figured out by now that if you need to turn all your cameras off you can do so in the settings section of the app or PC Mac software. Go to modes and select " all cameras off".
