How do I update the cell phone # on my account for notifications?
I can't seem to get that sorted.
Figured it out. Yes I was clicking 《edit》.
I needed to Add another method. I was interpreting the Trusted Device which was my phone as needing to have its # updated.
Perhaps a UI/UX thing for Arlo to consider (its confusing).
Phone numbers are for SMS messages which are not used except for 2FA.
Yes, understood. But I have a new phone # and am wondering where / how to update that for the 2FA if I need it in future.
Go into your Account Profile, and then choose Login Settings. After that choose Two-Step Verification.
Yeah. there's no phone # there. Only an email address.
I can choose the phone "Flip 3" but the only other option on the screen is the email address.
@egombrich wrote:Yeah. there's no phone # there. Only an email address.
Have you clicked "Edit" at the top right?
@Dannybear wrote:
You can also add method to access the sms option if not already enabled.
Just adding that SMS doesn't seem to be enabled at the moment.
@egombrich: The default is to use web-push to the app, and not SMS. Web-push doesn't require configuring the phone number.
