How do I adjust Arlo video recording length?
You can personalize your Arlo cameras to record videos from approximately 10 to 120 seconds long. On Arlo Pro Wire-Free, Arlo Q, and Arlo Q Plus cameras, you can also set your camera to record until motion stops, up to 300 seconds (5 minutes).
To adjust Arlo video recording length:
- Launch the Arlo app or log in to your Arlo account at arlo.netgear.com.
- Tap or click Mode.
- Select the base station or camera that you want to adjust.
- Tap the pencil icon or click > next to the mode for which you want to edit recording length.
Note: You cannot adjust recording length for Disarmed or Schedule modes, only for active modes such as Armed. - Tap the pencil icon or click > next to the rule that you want to edit.
If the mode only has one rule, it is preselected. - Tap the pencil icon or click > next to Record Video.
Note: If Record Video is not selected, you cannot edit recording length. - Select Record until activity stops (up to 300 sec) or select Record for a fixed length of time and move the slider to your preferred recording length.
- Tap < Edit Rule or click Back.
- Tap Done or click Save.
Your recording length is updated.
Thank you very much for your instructions! I never saw the 'Save' button and was wondering why a certain camera never retained my new recording length and kept reverting back to the default setting of 10 seconds as soon as I exit the 'Mode' section of my account. 🙂
The save button is so important!! But also awkwardly placed!! Glad it's working for you now
I must be missing a step or something. I've had my system for about 2 years and this has just been a problem recently. I go into Mode and it shows the base station Armed with the cameras listed below in a box titled Rules. There is no pencil, and when I click on Edit next to the camera I want to change, all I can get is Edit Rule. When I change the record time from 10 to 20, there is no Save button on that page and no Arlo Back arrow. All I can do is click my computer Back button, which takes me back to the Mode page showing the base as Armed. Again, no Save button. What am I missing?
have you tried using a different browser?
Christine, I noticed the same problem with the web interface. What you need to do is click "Edit Rule" next to Motion Settings to take you back a step and find the save button down the bottom of that page. Doing this will allow the new motion sensitivity setting to be saved
Thank you! That worked.
Gabriel123 wrote:
In mode settings it does not have an option to record until activity stops
Record until activity stops is only available for Arlo Pro cameras
