I need a scheduled Mode apart from Arm and Disarm modes for all cameras in the ARLO app so it will be easy to toggle between all 3 modes for all cameras. Now if I want to disarm and later switch to schedule mode for all cameras I will have to do it one by one
@ijselmuky wrote:
Makes sense! Any recommendations on base? I have mostly essential cameras
a VMB4540 is probably the best bet.
Do you have a wifi mesh (or use wifi extenders)? If you do, then you'd likely need multiple bases (which does reduce the benefits).
5 REPLIES 5
The answer to this depends on whether you are using a base/smarthub or not.
- If you are using a single base (with all cameras connected to it), then you can change the rules for all cameras by changing to a single mode. (all cameras at once).
- If you have multiple bases, you'll need to switch modes for each base (but not each camera).
- If you don't have any bases, then you will need to switch modes for each camera.
Thanks for the reply! Yes I am in 3rd option never used a base, what will be distinct advantages if I bring in a base? This mode change could be a simple enhancement to the ARLO app to include one more option?
- One advantage is that the mode can control all the cameras connected to the base.
- A second advantage is that you can connect local storage to the base/smarthub - using that either as backup or as a substitute for a subscription.
