Both phones are iPhone 7. Never had a problem till 2 weeks ago
Make sure that you have your location settings for Arlo as "always" through your iPhone settings. You can check this by going to your iPhone settings > Arlo > Location. If you still have problems, try to log out, uninstall the app, restart your iPhone, and reinstall the app to see if that helps too.
I have logged out and uninstalled on both phones still didn’t work now the FaceTime logo shows Arlo and the fix mentioned on the community doesn’t work you don’t have options to change it back to FaceTime. When you touch what should be the FaceTime icon it opens Arlo
For the video icon on your contacts page, you can hold onto the video icon and you can choose FaceTime from there.
For your Geofencing still not working, let me send you a private message to gather more information from you.
