Geofencing gone
System is basically useless now.
Now the option is even gone!!!!
Hey @Verymad,
Could you explain what you mean about Geofencing is gone? Are you experiencing this on both web and mobile app? What device and OS or browser version are you running?
Phone is Samsung s9 galaxy, up to date.
Geofencing was working , but very sporadic. Often not knowing if im home or away. Often arming itself when I'm sitting in my house.
Recently the geofencing option just disappeared off the app.
Thanks for the detailed info. Could you show a screenshot that shows where the geofencing option is missing from the app?
I
Use the mode tab, click on your base so the modes and (hopefully) geofencing show. Take a screenshot of that screen and attach it to your reply here.
Thanks for the screenshot. Have you tried reinstalling the app and rebooting your phone?
Now 10 hours later the geofencing option is magically back on the app.
Now if it will only work correctly.
It doesn't seem to run in the background. Usually only works correctly when app is open.
HORRIBLE CUSTOMER SERVICE!!!!!!
Hey @Verymad,
Have you tried clearing the cache for the Arlo app through the phone settings? And just to make sure, could you let me know the Android version your phone is running on and the Arlo app version?
Phone is up to date, whatever it is, and the app is your current one. Uninstalled, and installed again, multiple times.
It seems the arlo app just doesn't work. Nothing new...
Try these following steps on your Galaxy S9 where it states "Clear Individual App Cache" when clearing your app cache: Clear App Cache - Samsung Galaxy S9 / S9+.
What app are you using?
I still see it under modes on my Android app.
It never worked properly for me anyway. More of a worry is now I can only access 'mode' 10% of the time!
I have reached out to you via PM to gather more information to investigate in this further.
Giving the app phone permission allows the geofencing to work and appear under mode. Well seems too, I'll find out.
