For hardware problems you have to use the Contact Support link at the bottom here.
Have you swapped cameras around to see if it's the cameras or locations? There are a lot of reasons for disconnections including distance (doesn't seem to be the issue here), house construction, metallic objects in the signal path and 2.4GHz interference from other wireless devices.
There's no repair service as such but you can always invoke your warranty, typically 1 year in the US.
As for batteries, it depends on why you bought these cameras. The Pro series offers OEM li-ion batteries. There's been tons of discussion about the batteries here, both rechargeable and not. Having to buy rechargeables isn't cheap but it beats buying the non-rechargeables over and over, even at <$2/battery.
And video quality depends on needs and expectations. A 110 degree FOV and 720p resolution (<1 megapixel) coupled with compression leads to certain expectations that have to be set.
