Floodlight Pro 3 loose on mount
Camera is secured, double checked everything is locked in but through out the day this thing just keeps falling downward changing the angle of the camera. You’d think for the price this wouldn’t be an issue. Anyone else with this issue have a fix?
Message 1 of 2
944
You apparently haven't tightened the lock enough. It may seem like you're gonna break it but use pliers, if needed, to carefully tighten it.
Message 2 of 2
919
