Floodlight Pro 3 loose on mount
  • 1 Reply
  • 935 Views
folelbo2
Camera is secured, double checked everything is locked in but through out the day this thing just keeps falling downward changing the angle of the camera. You’d think for the price this wouldn’t be an issue. Anyone else with this issue have a fix?
Best answers
  • jguerdat
    You apparently haven't tightened the lock enough. It may seem like you're gonna break it but use pliers, if needed, to carefully tighten it.
