Fixing 'newer version of flash required' in Chrome!
  • 2 Replies
  • 7905 Views
  • 4 Likes
Bigblip
I used to be able to view videos online (logged into arlo.netgear.com), but now both Chrome and Firefox both are showing the 'newer version of flash is required' message - but both are completely up to date.
Given that everyone is trying to get away from Flash, I realized that I had to explicitly enable it for https://arlo.netgear.com
Solution for Chrome: https://helpx.adobe.com/flash-player/kb/enabling-flash-player-chrome.html
Firefox doesn't have the same site specific whitelisting capability, so I decided I'd just use Chrome.
Hopefully this helps someone else.
Note to Netgear product manager: PLEASE get rid of the requirement for Flash! The movement to ditch Flash is old news!
steve_t
Master Master
That's strange. Mine works fine. What versions of each are you running?
Bigblip
Firefox 53.0.3, 32 bit (Windows 10 Home 1703 on this Surface 3 tablet I'm testing on) gives the warning on the Devices page and will not play a live stream. However, recorded sessions on the Library page will play.
Chrome 59.0.3071.86, 32 bit acts the same unless I add https://arlo.netgear.com to the whitelist on chrome://settings/content
