  • 5 Replies
  • 3579 Views
bruhnau
Hi,
I'm trying to configure VMB3500 in a different account, but I keep getting firmware update failed, - is it because the Base station has been configured in a different account?
ShayneS
Hi @bruhnau
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
5 REPLIES 5
If it was properly removed form the old account ( remove device ), then there should be no issue.
Try a full reset ( hold in the reset for about 10 ses till the led flashes ) and then it should work.
bruhnau
Did you hold the reset button until the LEDs flashed amber (>10 seconds)?
bruhnau
ShayneS
Hi @bruhnau
