Hi Guys,
I just got my system updated with these firmware versions
Base = 1.4.2627
Camera = 1.2.2545
and it's really buggy.. I hope they'll release a new one soon and take care of it..
Problems:
1. Recording is randomly glitchy. It sometimes would not record even though it shows in my iphone's
Notification there's motion detected.. Library shows nothing.. Also checked on my email and there's none..
This is not good.. It beats the purpose of what this system does.. I can live with other glitch with this system
but not this one.. Earlier Firmware Version of base & camera were working fine..
2. iOs App 1.8.1 recently would crash on me randomly when accessing.. Especially when doing
scheduling or streaming from library.. Earlier Firmware Version was working fine..
3. When streaming live on my cameras, I sometimes have to press play several times coz it would not work the
the first time when pressed.. This is happening thru my iphone using the latest App 1.8.1.. Again, Earlier
Firmware versions of base & camera were working fine..
I wish I could go back to the earlier Firmware version..
Regards,
Jon
Good morning Arlo Community,
Thank you for all your posts. We are collecting logs and are continuing to investigate this issue. Once we have additional information to provide I'll be sure to post it as quickly as possible.
Thank you for bringing this to our attention.
Best Regards,
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
If you haven't done so already, try and restart your base unit and your iPhone.
I have been on the latest version for a couple of days now and don't see any of the issues you are having.
Hi sorry for the newbie question, however how do you update the camera firmware? I have the same base firmware 1.4.2627 however all my camera's firmware are reporting as 1.1.2074. I just installed the system yesterday, and having all kinds of intermittent issues connecting to the cameras, I'm hoping it's firmware related as I'm at my wits end troubleshooting this issue.
I hope that you are able to get your issue resolved. I'm going to see about updating the firmware on my cameras, any help there is appreciated, thanks!
Hi Robert,
I did pretty much the troubleshooting as it should and did not fix it..
It may be working for you and that's great.. It's definitely not working for me with this firmware version..
Again, I'm describing this issue as randomly glitchy especially with not recording at all
when motion is detected even though I get a notification and says there is.. I got this for a
couple of times now.. I am ok with other glitches but not the recording part..
I did not have this problem before in the earlier Firmware version..
I wish netgear would let us have access to which firmware best for us to install..
Hi Cyberjunky,
If you set your Base Station's "Auto Update FW" to Auto.. It should update itself.. If not, turn off all motion in
"Mode" and go back to Base Station settings and "Restart" it.. If it still doesn't do it, then do a power cycle..
If it still doesn't do it, then it's just a matter of having patience and wait and for it as long as your "Auto Update FW"
is set to Auto.. Coz' this basically what I did trying to update all I can and nothing happen and then the next day..
when I login to my iphone.. It was updated..
Thanks for the great suggestions, I've tried them without any success. I've opened a case with support to see what they have to say, in the meantime guess I'll have to wait it out and hope that it auto-updates sometime soon and fixes the connectvity issues that I'm having. Thanks again!
I found a version 1.2.2688 firmware for the VMC3030 here... just not sure how to go about doing a manual install of it...
Hi Showguy, I hope that you get your issue fixed soon, it sounds like we are all facing similar issues that may be related to firmware. I just bought the 4 camera system a couple of days ago (set it up yesterday), and have had nothing but intermittent issues with connecting to the cameras. I had read so many great reviews on this Arlo product, and am hopeful that a firmware update will fix these connectivity issues. I've wasted too much time troubleshooting this new install; I've come to the conclusion that it's nothing on my end causing any problems, it's a product issue.
In no way does it specifically relate to your situations but I have the latest firmwares and didn't know it until I happened to check today. No problems here.
I have base station 1.4.2627 and camera 1.2.2545. This morning I started having issues with motion being detected and no recording from said motion in the library. I, myself, triggered the motion and saw the camera counter on the app increment by one but when going to the library, the video never shows up. The system had been working flawlessly, in fact, a little too well as passing cars would get caught by the motion detection. I have also contacted support in regards to this issue and I urge all thos affected to do the same. This defeats the purpose of having these expensive cameras. For troubleshooting, I rebooted the base station, opened and closed the battery compartment on the camera, and attempted to access the library from Android, iOS, and Windows Devices. I just got an alert as I was writing this and guess what -- no video recorded.
Do you guys think it is a problem with the camera firmware or basestation? I have a camera that I have not hooked up since purchase that should be on the old firmware.
If you manually do a recording from the app, the video always shows up. Has Netgear acknowledged yet that this is an issue?
So I wonder if maybe it has to do with the base station firmware? I just installed this new system yesterday (it's never been working right for me out of the box), and it has the 1.4.2627 base firmware installed, however all 4 of my cameras appear to have an older firmware at 1.1.2074. I imagine the system was sitting on the shelf at Best Buy for awhile, and the base firmware auto installed when I first plugged it in, however by the time I got around to installing the batteries in the cameras, they never updated their firmwares. No matter what I do, I can't seem to get the camera firmwares to update either.
Since we are at different camera firmwares and same base firmwares with similar issues... the base firmware is common.
Showguy and RealDeal, those are both interesting observations, thank you. So if the manual recordings are always being captured, are they stored locally on the base station (and then updated to the cloud once a connection is established?) that could make sense on the intermittent connectivity issues to the cameras, and perhaps why my camera firmwares are not being updated (if they can't get pushed out from the server).
Showguy, yes, I want to update the cameras, it's just that I haven't yet been successful in doing so 🙂
Hi RealDeal,
I have 4 cameras connected and what you've just described bout' not recording is what I'm experiencing also..
Good to know that it wasn't just my system.. I did pretty much troubleshoot as you did and still having
the issue randomly.. I believe it's a firmware issue coz' before this update I wasn't having too much..
The Only issue I had the previous firmware was brightness & snapshot which it's unresponsive at night only..
Not a big deal to me at all.. Other than that it was recording perfectly and not having crashes..
This time though with this new firmware, I was hoping that it'll resolve the problem I had.. It gotten worse..
Now, I wish I could go back and reinstall the previous firmware..
Because we don't have access to which firmware that works for us, it becomes a BIG PROBLEM..
There's no way to learn which firmware is having problem whether it's the Base Station or Camera coz'
once you updated it there's no way to fallback..
There's NO reason why we have "Auto Update FW" switch.. They want us to Update Anyhow..
I think they should have it default as Off.. It should be Off all the time and it should be
replaced with "Firmware Update Only Box" where you can download from Netgear's support site with Release
Notes which update they did.. and when done you can upload it to your system.. Netgear should know this..
It's what they have on their modem/router products.. Right now we're all stuck with what we have..
Hi Showguy,
I firmly believe it's related to firmware issue.. I dunno if it's the Base or Camera.. If it's not a firmware issue,
then I think it's the way how the firmware was installed to our system since it's autoupdate and we don't have
much in control.. There could be a glitch somewhere when it was downloading and installing the firmware..
We really don't know.. When they came out with this new firmware, My Base Station was updated first and a day or 2
later my 4 cameras were updated..There was indeed a discrepancy.. The previous firmware when I updated my
system, both my Base Station and Camera updated same-day.. It could be a contributing causes also why
my system is having this non recording issue..Then again, it's a guessing game..
Cyber,
When my Base Station was updated, It took a day or two when my 4 camera's were updated..
It finally updated itself.. I just left it coz' I've had it with reset, powercycling, battery
opening.. non-work at all at the time when my Base-Station was updated.. Believe me I was looking forward
to this new update but now I wish I could go back..
Showguy, I just tested 3 cameras right now by walking around.. All three detected thru Push Notification and
Library shows 3 marked red in the bottom of my iOs 1.8.1 App but when I clicked it..
It only shows 2 videos recorded.. I think when cameras are idled for awhile then this happens.. I think that's what
I noticed bout' my system.. I really hope they'll fix this problem soon..
Having trouble since the update also.
13 Events recorded last night on my outoor cam that watches the wildlife. Only 3 showed in my Library.
And what's up with the lack of response from the Netgear staff ?
Best Regards,
Christine
Arlo Team
____
Please click
I have exactly the same issue here. Hopefully it can be resolved soon.
Is there not a way to manually revert back to previous firmware ? The system is now basically useless without the ability to record when motion is detected !
Anthony, Nope.. I really wish they could at least give us a way to revert back..
Yup, It's so frustrating that our system right now is useless.. Today, I have so many hits and misses on my
recording.. Invested $545 with this system with 4-cameras and now is useless..
