Extending the range in a concrete house
  • 2 Replies
  • 3551 Views
BazzaB
I have a large concrete tilt slab house and can only get the cameras to work down one end of the house. I already have wifi 3 extenders connected to a netgear ehternet switch. Do i just plug the Base Station into the ethernet swith and it will use the wifi extenders or do i need to add another Base Station.How do I add another base station to increase the range.
barry@soundvision.co.nz
You have two methods to increase your range under those conditions.... the cameras will ONLY talk to the base and not work alone thru an extender.
1) use a second base plugged into a wifi extender ethernet port ( set up on main wifi system first before moving ) IF the wifi extender has enough range too
2) run an ethernet cable ( up to a few hundred feet ) from your switch / ethernet port  of the main wifi system to the far end of the home and plug into a second base.
IMO, the first is easier if your extender has enough range and thru-put for the base, but the second would be the better choice long term as if needed you can split the cable in a simple switch for additional ports at the far end
It may also be useful to place the base station as high as possible to get better range.
