I cannot seem to get the ethernet from the netgear modem to talk to the comcast modem. When I try to sync, the ethernet light on the netgear modem starts flashing and no connection. I have switched ethernet cables, called comcast and still cannot complete the connection. Any other ideas will be appreciated.
Model numbers of the equipment might help. Normally you would hook the base station (it's not a modem) to a router that connects to the Comcast modem, not directly to the modem. If the modem is also a router with multiple Ethernet ports, that should work as long as there's communication going on between the two. Give us more details on the hardware and configuration.
I finally figured it out. The instructions say to push and hold the button on the side of the Netgear modem, however, you only have to push the button once and release to get it to sync. Thanks for you help.
JD
I would suggest you contact the online support. They walked me through the setup procedure and found that that the instructional manual was incorrect. Good luck.
