When I first got my wireless setup the system was working great. My only complaint was the battery usage. Since the last two updates I noticed I no longer can download a single video nor can I select the Favorite icon to save favorites. I have a basic subscription.
Funny you mentioned that, just this morning I attempted to d/l a few videos on a PC and the browser went to a new page and never d/l'ed
I had to log out and log back in , on the second try it worked....
PS have no idea as to why but I feel its on the other end and will clear up
judidaydreaming,
What browser/mobile app are you using that is behaving this way? I have not been able to replicate this issue.
Are you still seeing this behavior?
Unfortunately, if a power cycle of the base and cameras (open and close the battery doors) doesn't work, I suspect you'll need to reset the base and start fresh. Be sure to note your settings and modes/rules/schedule to aid in rebuilding.
ianatkin,
Are you able to download using a web browser from a different device (PC). Do you get the same behavior?
Hello there
I've just tried on the web browser and I can download through that no problem (although a couple of clips seem to be a much lower resolution than others)
Ian
