I have about 10 old Lithium batteries from using with ym Arlo. If I use my battery tested they all almost show good condition 90%+. yet if I stick 4 in my camera, Arlo says its at about 10%-15%. Can a conventional battery tester now read these batteries correctly?
PS ... The dropout point of the camera is 2.75-2.8 v
a new cellis 3.2v and you really need a voltmeter
I use a multimeter and check the voltage. Pretty much anything below 2.95 volts is unusable
